Helping in picking a proper LC filter values
Dever
Joined May 2, 2022
35
I returned to this circuit and I think it's not suitable for low duty cycle. I wanted have DC voltage when duty cycle is about 1-5%. Maybe I should create true buck converter and use relay to change polarisation?
MrAl
Joined Jun 17, 2014
13,791
Just curious, why do you need a 1 percent duty cycle?
Ian0
Joined Aug 7, 2020
13,269
It will work exactly the same.
Dever
Joined May 2, 2022
35
this circuits drivers Peltier module. The duty cycle is being set by PID. When Peltier reaches temperature, duty cycle is about 0-5%.
MrAl
Joined Jun 17, 2014
13,791
Hello again,
Oh ok, that makes sense.
A regular buck circuit should be able to do that, but since your H bridge circuit was going to be driven like a reversable buck circuit, I don't see why it would not work just like a buck.
What led you to believe that the H bridge circuit would not work for this application?
Danko
Joined Nov 22, 2017
2,235
MrAl
Joined Jun 17, 2014
13,791
See how you can filter it on 31.4 kHz:
Hi there,
That looks interesting. I was just wondering, did you happen to check the ripple current through C1?
I ask because the cap has to handle that as long as the circuit is running. I would feel more comfortable with 50uH or even 100uH, but that of course would be more expensive.
Dever
Joined May 2, 2022
35
Nice, thanks.
Sorry, I should have told that the load changed to 50W only.
The capacitor does the thing. The only matter that worries me in your circuit @Danko is unpolar operating.
MrAl
Joined Jun 17, 2014
13,791
Nice, thanks.
Be sure to get a capacitor that has a ripple current rating higher than you expect to see though that cap. That should do it i think.
