Hi,I returned to this circuit and I think it's not suitable for low duty cycle. I wanted have DC voltage when duty cycle is about 1-5%. Maybe I should create true buck converter and use relay to change polarisation?
It will work exactly the same.I returned to this circuit and I think it's not suitable for low duty cycle. I wanted have DC voltage when duty cycle is about 1-5%. Maybe I should create true buck converter and use relay to change polarisation?
Hello again,Hi,
this circuits drivers Peltier module. The duty cycle is being set by PID. When Peltier reaches temperature, duty cycle is about 0-5%.
Hi,I suggested the simulation results:
During low duty cycle, there are voltage spikes, not stable voltage.
____
Especially for you: inductor S14100036, 56 uH, 17 A, Digikey, $148.00 for 16 pieces. https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1284/S14100036.pdfI would feel more comfortable with 50uH or even 100uH, but that of course would be more expensive.
Hi there,See how you can filter it on 31.4 kHz:
Hi,Nice, thanks.
Sorry, I should have told that the load changed to 50W only.
The capacitor does the thing. The only matter that worries me in your circuit @Danko is unpolar operating.
| Thread starter | Similar threads | Forum | Replies | Date |
| G | Electret MIC and MAX4466 Picking Up VCC Noise (sometimes) | Analog & Mixed-Signal Design | 14 |
| Similar threads |
