Help with TOSHIBA 74HCT258AP
MorrAndSo
Joined May 24, 2017
9
Can someone help me with this little project?
I just started in electronics and I need help with this:
http://www.alldatasheet.com/datasheet-pdf/pdf/15576/PHILIPS/74HCT258.html
So i have the folowing components:
4x red LEDs (and 3 green LEDs for backup)
2x two-position buttons
1x 74HCT258AP multiplexor
4x 400 ohms rezistors
Please help me make it work on my breadboard:
I also have a peper scheme if u can help show me how to put the componets on the breadboard.
I don't know if the scheme is correct and if u don't think its good then please give me a better ideea.
The multiplexor should have 4 LEDs light-up.
I have to show it works for my project
Moderators note : merged images to reduce bandwith
MorrAndSo
Joined May 24, 2017
9
Welcome to AAC!
Is this homework?
Well its a project for school.....I just can't get my head around how it works. Espacially those S(selector) and OE (output enable). If you can show me a functional circuit on a breadboard you would be a GOD!
dl324
Joined Mar 30, 2015
18,501
This table shows functionality:
G# is the output; it's LOW active. When it's HIGH, the outputs are tri-stated.
A#/B selects either the A (LOW) or B (HIGH) inputs to the mux. The inputs are inverted at the outputs.
MorrAndSo
Joined May 24, 2017
9
I see.....its just that I can't make it work on my breadboard.......I don't know how the wireing woks with this component. Can you show me? Please! On a breadboard
MorrAndSo
Joined May 24, 2017
9
Here
What is it that you don't understand? How the breadboard connects things or how to wire the components?
Those exact 2 things that you mentioned give me problems "How the breadboard connects things and how to wire the components". Especially the S and OE pins.
bertus
Joined Apr 5, 2008
23,026
The breadboard has a couple of lines that are connected.
Read the attached PDF for more info on the breadboard internal connections.
Bertus
MorrAndSo
Joined May 24, 2017
9
Bertus
I know this. But how do I make it work with this component in particular is my question. What is the deal with OE and S and where do I connect 1I0 1I1, 2I0 2I1, 3I0 3I1, 4I0 4I1 and 1Y, 2Y, 3Y, 4Y.
How do I wire the components pins on the breadboard with the LEDs so that it will work?
MorrAndSo
Joined May 24, 2017
9
Ok. Tomorow, I will show you what I made on my breadboard and put further questions then. Thanks for the help guys!
bertus
Joined Apr 5, 2008
23,026
The nl0 and nl1 are routed using the S input to exit at nY\
The signal can only exit the chip when OE\ is low
(see the table next to the drawing)
Bertus
dl324
Joined Mar 30, 2015
18,501
Perhaps if you explain why you're using a multiplexer, we could help.
Since this is a school project, we won't do the work for you. It would be unfair to you and your classmates.
We have told you how the mux and breadboards work. If you post the complete wording of the problem/project, we can determine what the learning objective is and avoid helping you cheat.
