Help with some basic circuit analysis.
Emehgee
Joined Aug 2, 2018
8
Hey all,
I'm currently studying electrical engineering and working through my text.
I'm quite stumped on this one problem. I don't know how to start it as for all components there is only one given.
Am I missing something?? Any help would be greatly appreciated.
MOD: Rotated and shrunk your image. E
Jony130
Joined Feb 17, 2009
5,598
But you already have enough information. Do you know what properties a series connection and parallel connection have in a circuit?
Do you recognize any?
WBahn
Joined Mar 31, 2012
33,050
Try it starting from something you know. If you were given the value of R3 but not the current flowing in it, would you have enough information to find that current?
If so, the simply use the labels R3 and I3 for that resistance and current and then get a solution that gives you I3 if you know R3 and then solve that equation for R3 instead.
Emehgee
Joined Aug 2, 2018
8
Ok that makes sense to me I think. Going to keep plugging away.
Emehgee
Joined Aug 2, 2018
8
Thanks for the help. I think I was looking at too much from the circuit analysis side and not considering maths and algebra enough. Didn't think they'd put such a tricky question so early on.
dl324
Joined Mar 30, 2015
18,445
It's a simple series, parallel circuit that would be covered in a first term course.
dl324
Joined Mar 30, 2015
18,445
Lol. What a useless condescending reply. Thanks for your help bud.
You need to check your attitude at the door. I was just stating a fact. I had problems with series and parallel circuits at first, so don't feel bad.
If you'd take the time to show your work, we might be able to help you.
Emehgee
Joined Aug 2, 2018
8
I showed my work when you asked the first time. I've figured it out already and thanked folks since. I didn't have any issues with the circuit analysis part it was more the maths I was missing. Just seemed a strange final comment to make to me.
dl324
Joined Mar 30, 2015
18,445
There is no calculation for R3.
My comment was in response to you describing the problem as "tricky" for being "early on".
