Help with solid state SPDT switch using PNP transistors, to switch a Hall signal to an H-Bridge
sghioto
Joined Dec 31, 2017
8,758
Should work, are you sure its wired correctly?
Double check the pins on the FETs
With Hall low Q2 and Q3 should be the only two Transistors conducting.
Hamlet
Joined Jun 10, 2015
560
Alright, I changed things up, and used crutchow's recommendations:
It works, switching back and forth appropriately, but the current consuption with indicator leds is .93A at 6volts.
(I have two led place where the motor should go, with opposed polarity and dropping resistors as indicators)
As before, Q1 & Q2 stay cold, and Q3 & Q4 get hot.
Hamlet
Joined Jun 10, 2015
560
My bad I left out the resistor on the base of Q6. Should be as below.
You show Hall connected to Q5. You shouldn't need Q5, if Hall is open collector.View attachment 227525
Thank you for looking it over again. Yup, I ommitted Q5 and used the open collector of the Hall.
It's late, and I discovered a new bag of mosfet parts that were junk,
then another, then I ohm tested all my pads against ground looking for whiskers, trashed a few npn transistors...
But, it's working!
Time to order new parts.
sghioto
Joined Dec 31, 2017
8,758
For what's it worth the circuit I posted in #25 that was originally missing the resistor would have been correct had I not forgotten to change the transistor for Q6. Changed Q6 designation to Q5 and use FET.
Hamlet
Joined Jun 10, 2015
560
So we delete the 100k, and change the 2.2k on Q2 back to a 10k, lose an NPN, and gain a N-Mosfet. Interesting.
