help with Resonance circuit
JoeJester
Joined Apr 26, 2005
4,390
It also said for you to show the steps you've taken and show the work you have done ...
So what do you think happens when you change R1?
(1) What type of filter is C1 and R1 with respect to frequency bands?
(2) What is the formula to find the fc?
(3) Assign a value to C1 and R1. What is the fc? ... Show your work
(4) Decrease R1 by half. What is fc? ... Show your work
(5) Double R1. What is fc? ... Show your work.
(6) Review the results in 3, 4, and 5. What do you conclude from those results?
ronybhai
Joined Sep 18, 2012
97
I am not sure but i think the filter gets narrowed
fc=1/2pifC, Q=XL/R
BW=f0/Q ,
Low pass filter: AV=XC√ (R2+XC2) (-tan-1(R/XC)
High pass filter: AV=R/(R-jXC), AV=R/ (R2+XC2)
ronybhai
Joined Sep 18, 2012
97
so basically when I asked question about filters for example, I will put what I know about filters and how it relates to the question I asked right?
JoeJester
Joined Apr 26, 2005
4,390
Where did Xl come from? There are no inductors in your circuit.
According to your diagram, you have C, R, C1, R1. Your inquiry was concerning changing the value of R1.
(7) What kind of a filter does your diagram represent?
And just so we are straight, identify the question number you are answering.
JoeJester
Joined Apr 26, 2005
4,390
(8) C1 and R1 form one filter ... C and R form another. Identify them by name.
(9) What is the formual to find fc?
The quality formula has nothing to do with your inquiry.
ronybhai
Joined Sep 18, 2012
97
yeah..I know I just put basic formulas...for resonant circuit...
so there are tow different filters...so if you change R1 it will affect the whole circuit right?
JoeJester
Joined Apr 26, 2005
4,390
fc is the -3dB point where Xc = R in these filters.
Assign them the following values:
C1 - 0.47 uF
R1 - 10 k
C - 560 pF
R - 10 k
(9) Identify the two filters by their function name.
(10) Compute fc for each filter
(11) Identify the whole filter circuit by it's proper name.
ronybhai
Joined Sep 18, 2012
97
C1 - 0.47 uF
R1 - 10 k
C - 560 pF
R - 10 k
fc for 1st one is 33.86Hz
for 2nd one is 28.42Hz
so if decrease the capacitor critical frequency decreases.
dnt know 9 and 11
JoeJester
Joined Apr 26, 2005
4,390
the page just shows a diagram of filters
Read each of the links on the left.
so what is the correct one...i think i put wrong numbers on the equation
you missed it by a factor of 1000. Since you didn't show your work as you are suppose to, I can only assume you didn't enter in the number properly.
ronybhai
Joined Sep 18, 2012
97
The inductor's impedance increases with increasing frequency.
The capacitor's impedance decreases with increasing frequency.
but what happen to filter ...not ev en sure what kind of filter is the circuit I put...
A filter is an AC circuit that separates some frequencies from others within mixed-frequency signals.
So how does it affect when change the resistance value
i think it shud be either low pass or high pass ...or both?
