Help with relay selection please!
PepeLapiu
Joined Jul 8, 2019
32
hi,
What do you think will happen to the relay coil if you do that.?
E
I don't know. I would think it might help the relay release some of the smoke trapped inside it?
I was talking about the switch side of the relay. Could I use an automotive relay with a 12V coil to control a 120VAC circuit?
Ian0
Joined Aug 7, 2020
13,226
No, automotive relays switch automotive voltages: 12V
hi,
Post a link or a datasheet for the 12V relay you are considering.
E
I was recommending
https://uk.rs-online.com/web/p/non-latching-relays/4881954
to switch between the 120V AC from the mains and the 120V from the inverter
and
https://uk.rs-online.com/web/p/non-latching-relays/6995960
to switch the power to the inverter
ericgibbs
Joined Jan 29, 2010
21,528
hi P,
Did you read the product details in Ian's link.?
Product Details
MY Series
Switch power: 10A version: 1100W, 5A version 660W
Contact resistance: 100mΩ
Isolation coil to contact: 2000Vac
Operating temperature range: -55 to +70°C
Maximum switching voltage: 250Vac; 125Vdc
Contact material: AgNi
Dimensions: H42.4mm x W21.5mm x D28mm
And
Specifications
AttributeValue
Coil Voltage12V dc
Coil Power1.4W
Coil Resistance103 Ω
Isolation Coil To Contact500V rms
Contact ConfigurationSPDT
Mounting TypePanel Mount
Switching Current40A
Terminal TypeQuick Connect
Maximum Switching Voltage DC14V dc
Depth26mm
Height25mm
Length22mm
PepeLapiu
Joined Jul 8, 2019
32
hi,
E
I
hi,
E
I was not considering using auto relays, someone else in this thread suggested using auto relays.
But now that I think of it, he must have meant to use the relays to control the inverter 12V input from the battery, not the 120V output to the fridge.
Never the less, I already have these relays laying around: https://www.amazon.ca/gp/aw/d/B08J3VNJMB?psc=1&ref=ppx_pop_mob_b_asin_title
The fridge is 120VAC and 1.5A (165W I think). Could I use the relays above to control the power to the fridge?
PepeLapiu
Joined Jul 8, 2019
32
hi P,
Product Details
MY Series
And
Specifications
AttributeValue
Coil Voltage12V dc
Coil Power1.4W
Depth26mm
Height25mm
Length22mm
I actually originally dismissed it because I thought it was a latching relay. Now I see it's a non-latching one.
I'll look into it.
PepeLapiu
Joined Jul 8, 2019
32
Anyways. I want to thank you all for your responses. I learned just enough to be dangerous!
I also know I missed a few posts. Off to read them. Thanx again to all for your help.
Tonyr1084
Joined Sep 24, 2015
9,744
I'm not deliberately trying to be confusing (I can be confusing without even trying).
I wasn't sure if the TS had a 12V power supply, or whether it was a 12V battery charger
Not accusing anyone of anything. For sure, we could use a clearer picture of what the TS is doing - or trying to accomplish.
Also relays typically have a lower voltage signal to control a higher voltage switch.
Not necessarily. While it is more common to use a low voltage to trigger a higher voltage, sometimes the opposite is true. You CAN use the presence of a high voltage at a low current to switch a low voltage high amperage device.
Why is using the mains power as a signal the better way to go about it?
Not specifically necessary that way. If you power a power supply from mains you can use that lower voltage to switch in an inverter. It's just a matter of choice. My way of thinking on this is that if the power supply fails while mains are still present you will switch to battery operation when you don't need to. And a mechanical relay (analog as you called it) means it's impossible for the NC and the NO contacts to be active at the same time. One MUST break before the other can MAKE (contact).
Automotive relays would be used for 12V. But can I do that? Can I put 120VAC through a relay usually used for 12VDC?
Automotive relays are designed for DC circuitry. That's their intent. Switching an AC voltage can cause arcing that the contacts were not designed to handle; and that can lead to a very short lifespan of the contacts. Also, the spacing of the metallic materials and any insulation between them has to be considered. Just because a relay can handle high current doesn't mean it can handle high voltage. At some point the voltage can arc across the two nearest points of metallic structure and cause issues.
If you look at relays and their ratings you'll see that they are often rated to handle higher current at AC voltages whereas they are often much lower current rated for DC voltages.
Tonyr1084
Joined Sep 24, 2015
9,744
Says "Use for Car Auto Boat". However, I would not ask more than 7 amps through the contacts if using it to switch DC voltages. However, the "Center Off" feature (DPDT ON-OFF-ON) can be useful.
PepeLapiu
Joined Jul 8, 2019
32
That's good to know. I have some automotive relays I can use if I need to go over 7A. In fact most of the stuff won't really ho over 2 or 3A. So I'll slap on a relay if I go over 2A.
Is 7A just a guess of yours or a gut feeling? Or is there some math to it?
