Hi Guys,
I would be very grateful if you can help me with a project I am working on, which might be a no brainer for most here.
I want to create a circuit that gives a 5V output via USB.
It can work with normal batteries or rechargable batteries. With the option for recharging I guess it needs extra module for charging (via any regular mobile phone charger).
The cherry on the cake is that I want it to give output on the USB intermittently via set templates.
I would prefer this to be set manually or have predefined times - like 10sec on with 1min off, or 1 min on with 5 min of.
So when I connect a led light via USB, it it stays on as much a I’ve set it, like 10sec on and then 1 min of.
I look forward to any suggestion.
Thank you in advance,
M.O.
M.O.
