Help with MOSFET PWM circuit
OBW0549
Joined Mar 2, 2015
3,565
Yes, sorry the arrangement I had was connecting the Source to the +12V, drain to the LED positive (or the scope+load right now), and gate to pin 3. (...) Am I reading right that I incorrectly wired my MOSFET?
Yes, you incorrectly wired it. The LEDs would be on all the time, fed by the forward-biased substrate diode in the MOSFET.
secondarychaos
Joined Apr 6, 2015
17
Vgs must be 10V to turn the device on fully. Notice the substantial drain current (7.5 Amperes).
Noticed that as I hook up the load, my output voltage dropped- I'm guessing this is due to the required Vgs.
Wiring the MOSFET to switch the ground will fix this as well, correct?
RamaD
Joined Dec 4, 2009
328
Am I reading right that I incorrectly wired my MOSFET? that is, I wired the Drain to my load and the Source to +12V,.
Right. The body diode of the MOSFET is conducting the +12V from the source to the drain (output)!
secondarychaos
Joined Apr 6, 2015
17
Hmm... well this one is interesting.
After wiring the MOSFET to switch the ground, I've hooked it back up to the load and scope, to see this:1428427485014-979476100.jpg
It would seem I'm getting a pwm signal through, but my voltage isn't dropping to 0 between pulses (note the offset on the trace)
Alec_t
Joined Sep 17, 2013
15,166
The drain voltage won't drop to 0V. If the FET RdsOn is 100mΩ and your LED current is 2.5A (30W LED string) it won't drop below ~ 0.25V.
OBW0549
Joined Mar 2, 2015
3,565
You should be getting within a gnat's whisker of +12V on the drain when the FET is off, and just a few tenths of a volt above ground when it's on. Anything else, and you've either got a dead FET or you've connected it wrong. This really, REALLY should be simple...
ScottWang
Joined Aug 23, 2012
7,509
Your circuit is quite strange, the oscillator is fast, but the Monostable is very slow, and if you use the N type mosfet then you should connect the load to the D pin and 12V, and the S pin connected to Ground, otherwise it will hard to work properly, because the Vgs needs 10V to turn it on, if the load needs 12V then you have to offering a 10V+12V=22V, and it should be separate from 12V, then the mosfet can be work properly.
If you need a pwm circuit, check this and you just choosing the PWM function.
secondarychaos
Joined Apr 6, 2015
17
Your circuit is quite strange, the oscillator is fast, but the Monostable is very slow, and if you use the N type mosfet then you should connect the load to the D pin and 12V, and the S pin connected to Ground, otherwise it will hard to work properly, because the Vgs needs 10V to turn it on, if the load needs 12V then you have to offering a 10V+12V=22V then the mosfet can be work properly.
Yeah, it was the best I could piece together from reading wiki articles.
The other contributors in this thread have suggested that I use the MOSFET to switch the ground for the Vgs reason mentioned
I'm starting to think I may have miscalculated the monostable circuits timing
But, all goofiness aside I could Have this running if the mosfet would turn all the way off.
I'm going to double check my scope probe leads to make sure I haven't screwed that up, and been looking at the wrong thing.
