Help with LT3751
MGPERF
Joined Jun 8, 2021
77
I am trying to have the LT3751/ga3459 run continuously when supplied with 12V to make things a bit simpler I am also disabling over voltage and under voltage. My supply will be a steady 12 volts. The datasheet says connect to UVLO2 and UVLO1 to VCC however it does not mention any resistors or anything to do that. Would I need them? Any harm in having them/not having them? I cannot find an up to date and working LT Spice model for LT3751 so I'm kinda stuck ordering and hoping for the best.
Jon
ronsimpson
Joined Oct 7, 2019
3,045
Data Sheet said:
UVLO2 (Pin 4/Pin 2): VCC Undervoltage Lockout Pin. Senses when VCC drops below:
VUVLO2 = 1.225 + 50µA •
RUVLO2 and trips the FAULT latch low, disabling switching. After VCC rises above VUVLO2, toggling the CHARGE pin reactivates switching
The pins have a 50uA pull down. A 1.22V trip point. And a external resistor that pulls up. Ohm's law.
MGPERF
Joined Jun 8, 2021
77
Ron,
Great thanks my 100k resistors should do the trick then. Everything else look good? Mostly followed data sheet. More or less I’m looking for a simple hv power source. Niche application so I’m not super worried about core losses from running the transformer all the time.
