Help with Digital works (Circuit Design)
julieanna813
Joined May 23, 2019
been told to design a circuit with:
- 2 digits BCD adder/subtractor using XNOR as controlled inverters for 1's complement (using full adder macro)
- 1 switch for mode (0 for add, 1 for subtract)
- 0-9 numeric keypad with priority encoder for the A and B inputs
- 7-segment display indicating polarity (small letter "c" if positive, "-" if negative)
- 3 7-segment display (common cathode) with BCD driver (7447 IC) for the final answer
hope you guys can help me. thanks in advance
dl324
Joined Mar 30, 2015
18,471
Welcome to AAC!
Post the the entire text for the problem, you're work, and what problem you're experiencing.
