hi I need help creating a circuit. I have an NPN output that varies from "high" to "low". I need to level shift this to two voltage V2 (low) and V3 (high). I also need to detect OPEN and SHORT Loads. I can do everything except detect the open.
The problem I have is that I can put a current sense at the output, then when the load is removed I can compare with and without load. The issue is that I am trying to do everything under a single wire and I am running into feedback issues because I am comparing the output that I am trying to control at the same time
