I am designing a current DAC (NMOS element) that sinks the output of another current DAC (PMOS element). For biasing the NMOS, I connected the gate of each transistor to its drain through a switch driven by a select bit, and the drain is connected to the output of the DAC. I am concerned if this would work well as the select bits are synced with a clock so there is constant switching between the gate and drain, hence involving the possibility of charge injection. Can you help me with ideas for biasing the NMOS?
