My Samsung Monitor (320P) is flashing about 100 times during power up. I have isolated the problem to 3 bad Capacitors in the main power supply just by their appearance (Domed Tops). This is a typical problem facing Samsung Monitors.
The Capacitor Values are:
1000uf/35v/105 deg.C/Radial/Through Hole/12mm(D) x 23mm(L)
2200uf/35v/105 deg.C/Radial/Through Hole/16mm(D) x 30mm(L)
The unknown Values are Tolerance and ESR. Would 10% be okay, or should I look for a lower Tolerance? I have no idea what would be a good ESR Value.
Any suggestions would be helpfull
Thanks.
Thanks.
