Help with analog circuit design
ANDONG
Joined Dec 5, 2023
Design an audio signal amplification circuit using a triode.It is required to amplify the signal without distortion:
1. the signal source voltage is 10mV and the signal source internal resistance RS = 500Ω;
2. Amplification 1000 times;
3. Load resistance RL = 8Ω
Ian0
Joined Aug 7, 2020
13,255
The absolute maximum gain you will get from a triode valve is the value of μ.
There are no triodes with μ>125.
You would struggle to get a gain of 1000 from a pentode.
No triode can drive an 8Ω load. You would need a transformer.
Read Merlin Blencowe's book if you are interested in valve design.
https://www.waterstones.com/author/merlin-blencowe/1076386
WBahn
Joined Mar 31, 2012
33,125
Where are these requirements coming from?
What does it mean "without distortion"?
There WILL be distortion, you need a spec on how much distortion is acceptable (which included indicating what kind of distortion).
Papabravo
Joined Feb 24, 2006
22,111
This is homework help, not homework done for you. You need to show your best efforts at developing a solution. A good start would be telling us what you already know.
BobTPH
Joined Jun 5, 2013
11,637
A regenerative RF circuit can attain ridiculously high gain with a single triode or transistor.
But certainly not with no distortion.
Ian0
Joined Aug 7, 2020
13,255
I learned transistors first, and valves later out of curiosity “what are these weird high-voltage JFETs in glass tubes all about?”.
I have heard of regenerative circuits, but the TS did say “audio”, and regeneration (usually from microphones) in audio is not usually a good thing!
