Help with a circuit for making LED lamp
depaul73
Joined Jan 7, 2017
I want to make a circuit for switching on LEDs as shown in the attached picture. The circuit shown is to just depict what i want to achieve(I know this is not right). A slider which on sliding up will switch on the LEDs. If it is on the first level only one LED lights on. On the second level it should switch on both the lower and the corresponding LED and so on. I have no idea as to how to achieve this. Maybe a circuit as shown below. I really don't know anything about electronics. So a little help will be really appreciated. Thank you in advance.Screenshot (75).png
AlbertHall
Joined Jun 4, 2014
12,653
Each diode will drop at least 0.3V (for schottky diodes) so the bottom LED will see 1.2V loss from the battery voltage when the switch is at the top. That bottom LED will get dimmer and dimmer as more LEDs are switched on. You can minimise that effect by using a higher supply voltage (1.2V lost from 12V, for instance, is a relatively small proportion. Another way would be to use mode diodes. The third switch from the bottom would have a diode to each of the first two, the fourth switch would have three diodes, one to each lower Led and similarly for the top switch. This would mean that each LED would only lose one diode drop from the supply voltage but would require ten diodes.
dannyf
Joined Sep 13, 2015
2,197
I think you will find it much easier to then start learning the basics of electronics and graduate to building what you wanted to build here.
Even if someone can provide you with a schmatic or two, without knowing anything about electronics, your chance of realizing it will be slim at best.
depaul73
Joined Jan 7, 2017
Thanks a lot!
Alec_t
Joined Sep 17, 2013
15,158
The LM3914 integrated circuit in 'bar mode' responds to a rising voltage (which could be derived from a sliding or rotary potentiometer) to drive a column of LEDs as you describe, but additional components would be required to complete the circuit.
