Help with 741 amp or any other
ibrahim abukharmeh
Joined Nov 10, 2015
13
i am trying to make ua741 op amp works as non inverting amp
i have connected the very basic circuit consisting of two resistor Rf and Rin
and the gain now should be 1+(Rf/Rin) but the problem is that gain is always one
i have connected it in inverting and tried different values for the resistor but it still not working
Well, honestly i think i burnt the amp by directly connecting +Vcc to 12 v 600mA source and -Vcc to gnd
and i later calculated that i would need 288 ohm resistor to be connected (not sure from that)
i calculated by looking at the datasheet the maximum power for that amp were 500mW and my input is 12 v
so the max current is 41,66mA and the resistor would be 288 ohm.
now before trying to connect a new amp, i am trying to realize what could went wrong
from my power supply what circuitry should be connected before the amp
do i need +12 and - 12 even though i am just trying to amplify a positive signal all the time (out put from Wheatstone bridge)
what wrong with the following simulation circuit, why its not working
Thanks A lot
DickCappels
Joined Aug 21, 2008
10,661
I doubt you hurt your opamp. When connected to a power supply the opamp will only draw the current it needs, no need to add any resistors.
I am surprised you get an output from that circuit. The TI LM741 datasheet says that it needs at least a ±10V power supply, and your schematic shows the equivalent of ±6 V. The LM741 was designed in the days of ±15 volt supplies being common and was not intended to operate from a single power supply. Many modern opamps work beautifully with single low voltage power supplies. Even old war horses such as the LM358/LM324 aren't bad at all for many applications.
The input voltage range (or "common mode input voltage range" in the datasheet) is specified to include 3 volts above the negative power supply and 3 volts below the positive power supply. Your circuit biases the + input at the edge of what would work if you had enough voltage.
kubeek
Joined Sep 20, 2005
5,796
Also the feedback is confusing. R1 is not doing anything, so you can replace it with a piece of wire, and when you do that you realize R2 is doing nothing as well, so you can delete it. You end up with a voltage follower.
DickCappels
Joined Aug 21, 2008
10,661
Woops! kubeek just pointed to a large error -why the gain is always one!
R1 should be between the output and the inverting input, not between the R2 and the inverting input. Rf in the circuit below is your R1.
ibrahim abukharmeh
Joined Nov 10, 2015
13
Well, thank you for the simulation error it caused me headache this morning and now i am laughing on my self, on the bread board i didn't do that error and i was not getting the needed gain, any recommendation for an amplifier that would work with 12 or even 5 volt (other than lm358) .
DickCappels
Joined Aug 21, 2008
10,661
I would think the LM358 is one of the easier opamps to find most places in the world.
Here are some along with their minimum power supply voltages. You will need to run them at a higher voltage than specified to assure operation. Also check the datasheets to see whether the opamp has sufficient output swing for your experiments. Some of these might be damaged with a power supply voltage of more than six volts, here again the datasheet is your friend.
ICL7650 10V
LF412 10V
TL031/32/34 10V
TL051/52/53 10V
LM118/218/318 10V
TLC2272/2274 9V
NJM2068 8V
LM833 8V
NJM2068 8V
TL070/71/72/74/75 7.5V
TL081/82/84 7.5V
TL01/72/74 7V
NE5532-3 6V
OP07 6V
TLC2201/2/4 5V
L272M 4V
TL061/62/64 4V
TLC2652 3.8V
LM324 3V
TLC27L2 3V
TLC272/277 3V
LMR321/358/324 2.7V
LMV321/358/324 2.7V
TLV2270/2771/2772/2773/2774/2775 2.5V
NJU7051/7052/7054 1.0V
dl324
Joined Mar 30, 2015
18,383
Would you care to elaborate on why you think LM358 are to be avoided?
A true craftsman will have a lot of tools in his tool box and be proficient in the use of all of them. I've found that LM358 can be used for most of my opamp circuits. You need to understand the capabilities and deficiencies of any components at your disposal, know how to utilize them effectively, and make appropriate choices.
Using a high bandwidth, high slew rate, high output current, low bias current, low offset voltage, and/or rail-to-rail input/output opamp when it isn't necessary is one option; but it doesn't show any finesse.
MikeML
5,444
There is some other things going on that you need to be cognizant of...
Look at this simple LTSpice sim of two different versions of your circuit using a LM358 and a single 5V supply. The plot is V(out) vs V(in), i.e. a plot of the transfer function.
Here are some things about the sim you should be able to answer:
1. Why can't V(out1) or V(out2) go below zeroV?
2. Why can't V(out1) or V(out2) go above ~4V?
3. Why is the gain (the slope) of V(out1) = V(out2)?
4. Why is Vout(1) shifted upward by 2.5V as compared to V(out2)?
ibrahim abukharmeh
Joined Nov 10, 2015
13
Well, as it turned out that my amp were labeled as ua741, but i was not expecting that since i asked for lm741
anyway, yesterday i connected two 9 volt batteries, to overcome the issue with vcc and vee. but the problem still persist,
maximum gain i was able to get, was about 80% of the calculated gain, will try to buy some other amps today and see if the problem
is from it. otherwise i am doing something wrong on the breadboard and in that case i will try to attach some photo
so it can be clearer situation, thank all for help, will keep updated.
22,084
There is no difference. One was manufactured by Fairchild and the other was manufactured by National Semiconductor. They're both long gone so there is nobody to complain to.
ibrahim abukharmeh
Joined Nov 10, 2015
13
What are you connecting to the output of the opamp as a load (nothing to do with the gain setting resistor)?
I am not connecting any load resistor to the amp, i am just trying the basic functionality right now, and then i will try to connect that to the analog input of micro controller.
ibrahim abukharmeh
Joined Nov 10, 2015
13
non inverting mean if input is +ve it will output -ve, vice versa
Sorry i dont get what you mean, as far as i am concerned an non inverting means that that output signal of my amp would have the same polarity of my input in the direction, and the magnitude would be the gain multiplied by the input signal which is
k = (1 +(Rf/rin))
ibrahim abukharmeh
Joined Nov 10, 2015
13
Could you please do me a favour and prove that mathematically or from simulation
basic control system analogy the output is the transfer function multiplied by the input, here our transfer function is the gain
and since that the gain equation is proven to be 1+(Rf/Rin) then we would never get flipped sign from the input
(last time i checked there was no negative resistors on EBAY):)
the site you copied what you said from, if you scroll down a bit, you would see in the mathematical example that the input was 0.5 V, the gain was 11 and the output is 5.5 volt,
could you please tell me where the switch in sign come from.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
sorry, i was telling of INVERTING AMPLIFIER. This means that if the voltage going into the741 chip is positive, it is negative when it comes out of the 741.
MikeML
5,444
Since you are actually breadboarding the circuit, measure the resistors with an Ohmmeter. Perhaps one of them is not what you think it is...
