I'm trying to write on the 2nd and 4th line of my 2004a LCD.
Im using it in parallel (DB0-DB7) and not in I2C. Therefore I have to manually write.
For now, in both 1- and 2-row configuration when I write something it gets displayed on the 1st row and then it goes to the 3rd row as expected.
I would like to be able to address the 2nd and 4th row too but in the SPLC780D Datasheet as well as online I couldn't find any help.
Whit SetDDRAMLCD() it doesn't seem like it's working right even if i use the same commands as in the datasheet example.
Attached is the LCD.c I'm using
Code:
// FILE: LCD.c
// TITLE: Driver for LCD
// V E R S I O N I
// V1.0: 23.8.2020 versione iniziale
// Included Files
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
#include <stdint.h>
#include <stdbool.h>
#include <stdio.h>
#include <time.h>
#include <stdlib.h>
#include "LCD.h"
void InitLCDGpio()
EALLOW;
// Enable internal pull-up for the selected pins
// Pull-ups can be enabled or disabled by the user.
// This will enable the pullups for the specified pins.
// Comment out other unwanted lines.
GpioCtrlRegs.GPAPUD.bit.GPIO0 = 0; // Enable pull-up for GPIO0 (E)
GpioCtrlRegs.GPAPUD.bit.GPIO19 = 0; // Enable pull-up for GPIO19 (RS)
GpioCtrlRegs.GPAPUD.bit.GPIO1 = 0; // Enable pull-up for GPIO1 (D0)
GpioCtrlRegs.GPBPUD.bit.GPIO44 = 0; // Enable pull-up for GPIO44 (D1)
GpioCtrlRegs.GPAPUD.bit.GPIO2 = 0; // Enable pull-up for GPIO2 (D2)
GpioCtrlRegs.GPAPUD.bit.GPIO3 = 0; // Enable pull-up for GPIO3 (D3)
GpioCtrlRegs.GPAPUD.bit.GPIO4 = 0; // Enable pull-up for GPIO4 (D4)
GpioCtrlRegs.GPAPUD.bit.GPIO16 = 0; // Enable pull-up for GPIO16 (D5)
GpioCtrlRegs.GPAPUD.bit.GPIO17 = 0; // Enable pull-up for GPIO17 (D6)
GpioCtrlRegs.GPAPUD.bit.GPIO13 = 0; // Enable pull-up for GPIO13 (D7)
// Set qualification for selected pins to asynch only
// This will select asynch (no qualification) for the selected pins.
/*GpioCtrlRegs.GPBQSEL1.bit.GPIO32 = 3; // Asynch input GPIO32 (SDAA)
GpioCtrlRegs.GPBQSEL1.bit.GPIO33 = 3; // Asynch input GPIO33 (SCLA)*/
// Configure LCD pins using GPIO regs
// This specifies which of the possible GPIO pins will be LCD
// functional pins. Comment out other unwanted lines.
GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 0; // Configure GPIO0 for GPIO0 v
GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 0; // Configure GPIO19 for GPIO19 WARNING: USING GPAMUX2
GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 0; // Configure GPIO1 for GPIO1
GpioCtrlRegs.GPBMUX1.bit.GPIO44 = 0;
GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 0; // Configure GPIO2 for GPIO2
GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 0; // Configure GPIO3 for GPIO3
GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 0; // Configure GPIO4 for GPIO4 v
GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0; // Configure GPIO16 for GPIO16 WARNING: USING GPAMUX2 v
GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0; // Configure GPIO17 for GPIO17 WARNING: USING GPAMUX2
GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 0; // Configure GPIO13 for GPIO13
GpioCtrlRegs.GPADIR.bit.GPIO0 = 1; // Configure GPIO0 as output
GpioCtrlRegs.GPADIR.bit.GPIO19 = 1; // Configure GPIO19 as output
GpioCtrlRegs.GPADIR.bit.GPIO1 = 1; // Configure GPIO1 as output
GpioCtrlRegs.GPBDIR.bit.GPIO44 = 1; // Configure GPIO44 as output
GpioCtrlRegs.GPADIR.bit.GPIO2 = 1; // Configure GPIO2 as output
GpioCtrlRegs.GPADIR.bit.GPIO3 = 1; // Configure GPIO3as output
GpioCtrlRegs.GPADIR.bit.GPIO4 = 1; // Configure GPIO4 as output
GpioCtrlRegs.GPADIR.bit.GPIO16 = 1; // Configure GPIO16 as output
GpioCtrlRegs.GPADIR.bit.GPIO17 = 1; // Configure GPIO17 as output
GpioCtrlRegs.GPADIR.bit.GPIO13 = 1; // Configure GPIO13 as output
EDIS;
/// Function that write a string to the LCD
/// Input: Data: String o characters (max 40)
/// RS: 0 = Instruction Register
/// 1 = Data Register
/// Max Data length = 40 (20 on the first line and 20 on the 3rd line)
/// To be implemented yet: Write up to 80 characters and dived on the four lines
void writeByte2LCD(char Data, char RS)
// set bit to parallel port
// ATTENTION! DO NOT USE GPxDAT because use read modify write and
// you must wait some time before changing the next bit if not
// the valure is not correct
//see SPRUH18H–January2011–RevisedNovember2019 chapter 1.5.3
if (RS & D0_MASK) GpioDataRegs.GPASET.bit.GPIO19 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO19 = 1;
// set E to 1
GpioDataRegs.GPASET.bit.GPIO0 = 1;
// SET or CLEAR the DataBus BIT
//D0
if (Data & D0_MASK) GpioDataRegs.GPASET.bit.GPIO1 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO1 = 1;
//D1
if (Data & D1_MASK) GpioDataRegs.GPBSET.bit.GPIO44 = 1;
else GpioDataRegs.GPBCLEAR.bit.GPIO44 = 1;
//D2
if (Data & D2_MASK) GpioDataRegs.GPASET.bit.GPIO2 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO2 = 1;
//D3
if (Data & D3_MASK) GpioDataRegs.GPASET.bit.GPIO3 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO3 = 1;
//D4
if (Data & D4_MASK) GpioDataRegs.GPASET.bit.GPIO4 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO4 = 1;
//D5
if (Data & D5_MASK) GpioDataRegs.GPASET.bit.GPIO16 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO16 = 1;
//D6
if (Data & D6_MASK) GpioDataRegs.GPASET.bit.GPIO17 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO17 = 1;
//D7
if (Data & D7_MASK) GpioDataRegs.GPASET.bit.GPIO13 = 1;
else GpioDataRegs.GPACLEAR.bit.GPIO13 = 1;
//wait 2us
DELAY_US(2);
//set E to 0
GpioDataRegs.GPACLEAR.bit.GPIO0 = 1;
// wait 100us
DELAY_US(100);
void SetDDRAMLCD(int address){
writeByte2LCD(0x80|address,0);
DELAY_US(3000);
void ClearLCD()
writeByte2LCD(0x01, 0);
// wait at least 1.16ms
DELAY_US(3000);
void ReturnCursorHomeLCD()
writeByte2LCD(0x02, 0);
DELAY_US(3000);
void InitLCD()
// Function SET: select 8 bit interface and 2 lines and 5 x 8 dots
writeByte2LCD(0x30, 0);
// wait 100us
DELAY_US(100);
// DISPLAY ON/OFF CONTROL:
// Display ON
// CURSOR ON
// BLINK OFF
writeByte2LCD(0x0E, 0);
DELAY_US(100);
//ENTRY SET MODE
// Mouving direction right
// no shift
writeByte2LCD(0x06, 0);
DELAY_US(100);
ClearLCD();
void InitLCD1()
// wait 100us
DELAY_US(100);
// Display ON
// CURSOR OFF
// BLINK OFF
writeByte2LCD(0x0C, 0);
DELAY_US(100);
//ENTRY SET MODE
// no shift
DELAY_US(100);
ClearLCD();
void WriteStringLCD(char *str)
while (*str)
writeByte2LCD(*str, 1);
str++;
DELAY_US(100);
