Hey guys, sorry for a totally newbie question, but I need help wiring an IR relay to my electric projector screen Here's why:
I recently purchased the harmony smart hub (basically a universal remote hub that only outputs IR) but I need it to connect to my electric projector screen, (which uses an RF remote). I am able to program an unknown IR remote into it, so I was thinking one of these IR relays should do the trick. (also my projector screen has wire terminals that will allow the remote's functions to be triggered by an actual wire. (see pics)
I assume it's possible to connect the outputs of the IR relay to the projector screen wire terminals, to be able to control my projector screen with an IR remote (which can later be added to the harmony hub) I only need the up/down functions to work.
My only problem is I'm not sure what these labels on the terminals mean, and what type of power supply I can use. (I assume just some power brick that I will solder to the board?
In conclusion, what would be most helpful is if you could define what the terminals all mean, and potentially even make a wiring diagram that describes what I need to plug into what to allow the included IR remote to control the projector screen.
Thanks!
Link to IR Relay:
http://www.ebay.ca/itm/24V-2-Channe...454989?hash=item2f0b43ca4d:g:iNwAAOSwEWtZtgFs
Thanks!
Link to IR Relay:
