Help wire motor
Sim085
Joined Dec 10, 2014
9
I have an AC 3 speed fan motor. The only thing written on the motor is "230V 50Hz 38W". It has six wires; black, yellow, brown, red, blue and white.
I spent a couple of ours trying to get this motor to work but can't seem to manage. The main problem I have is that I do not know what the wires represent.
I am quite positive that the yellow and black wire should be connected to the capacitor as the old capacitor that came with this motor has these two wire colors attached to it. For the rest I do not know.
At first I thought that the brown should be connected to the Live and the blue, red and white used to determine the speed. However when doing this nothing happens. If therefore experimented a little and connected the blue with neutral and red with live. The motor makes a strange loud noise but does not turn and I cannot turn it by hand (hard).
Does anyone know how the motor should be connected?
Note: I bought new capacitors so the capacitors should not be the problem.
30,655
Did you test the resistance of the windings to see if they are separate at all?
Traditionally the main winding would be white/blk, but not always true.
Sim085
Joined Dec 10, 2014
9
30,655
If you have one main winding, this would be connected all the time to the AC, if all the rest show continuity between them then I would expect one end to be connected to one side of the ac and the Capacitor switched from the other side of the ac to a particular coil/winding for speed selection.
IOW, check if you have one winding on its own and the rest connected, or if there are three separate windings.
Sim085
Joined Dec 10, 2014
9
Not sure if I am understanding this correctly. I have put the multi-meter on continuity. If I touch the blue wire with the red wire I get the reading 313, the blue with the white returns 176, white with red returns 190. For all other wires, black, yellow, brown I get no reading (i.e. 1). I am not sure if this is what asked to do? Touching any of the wires and the coil returns 1 too.
30,655
What is the 'Coil' you are referring to, and when you say no reading (i.e. 1) you mean it is essentially 0 resistance, not infinity (open)?
You either need to map the reading out a little better or draw a pic etc.
bwilliams60
Joined Nov 18, 2012
1,450
Maybe send a picture of the meter you are using as well. A reading on a cheap meter of "1" is the same as O.L on a Fluke meter. Infinite resistance. Take a picture of the reading with the coil connected.
Sim085
Joined Dec 10, 2014
9
I am not sure if we mean the same when I say coil and you say Winding. I have attached a photo with an arrow to what I call the coil.
https://dl.dropboxusercontent.com/u/27542229/motor/Coil.JPG
Here is a table of the readings I get when I set multi-meter to continuity and touch each wire:
Code:
|        | Black | Yellow | Brown | Blue | White | Red |
| Black  | 0     | 1      | 1     | 1    | 1     | 1   |
| Yellow | 1     | 0      | 1     | 1    | 1     | 1   |
| Brown  | 1     | 1      | 0     | 1    | 1     | 1   |
| Blue   | 1     | 1      | 1     | 0    | 143   | 290 |
| White  | 1     | 1      | 1     | 143  | 0     | 147 |
| Red    | 1     | 1      | 1     | 290  | 147   | 0   |
Sim085
Joined Dec 10, 2014
9
I have attached photos of multi meter.
This is when open citcuit:
https://dl.dropboxusercontent.com/u/27542229/motor/2014-12-11 21.39.49.jpg
This is when closed citcuit:
https://dl.dropboxusercontent.com/u/27542229/motor/2014-12-11 21.40.16.jpg
This is when touching blue wire and red wire:
https://dl.dropboxusercontent.com/u/27542229/motor/2014-12-11 21.39.39.jpg
Zero is when it is closed circuit.
You still also need to qualify whether you intend '0' as zero resistance (shorted) or open circuit?
bertus
Joined Apr 5, 2008
22,922
Do I see the battery low indicator on the left bottom side of the LCD?
If so, replace the battery and repeat your measurements.
Sim085
Joined Dec 10, 2014
9
Replaced battery with a new one. No longer have symbol. However I get same results!
What is wrong with my results?
What ever I try with the multi-meter I only get a value change when touching any of the red, blue or white wires.
bwilliams60
Joined Nov 18, 2012
1,450
What I see is two coils or windings in series but after that, I see nothing. Bertus, Max, maybe you can get more out of this. The zeroes represent nothing in his chart. What type of fan are we talking about. Any manufacturer markings on the housing, fan housing etc.
Sim085
Joined Dec 10, 2014
9
The fan was similar to this:
http://g-ec2.images-amazon.com/images/G/01/vince/jarden/detail/fans/B001707LPY/1._SL1000_.jpg
(Not same model)
It was a small fan with two motors, the big one (this one) which rotates the main blade, and a smaller motor to deviate the wind round a room.
This is all I know about the motor. It has three speed (I always thought these are the blue, white and red wires). It had a capacitor connected to it. Unfortunatly it did not have any manufecturer details on it. Tried to search on Internet to see how it should be wired to the AC but could not find much.
