Help w/ Remote drapes
Joseph gravel
Joined Feb 6, 2022
MrAl
Joined Jun 17, 2014
13,810
Is that an infra red remote? If so, you point it at the unit you want to use it with. This of course means every unit has to be visible to the remote. If not, you can use fiber optics or mirrors in some cases.
If it is an RF remote each unit usually has to have it's own access code or a different frequency. You would then have a different button on the remote for each unit (in most cases).
They make these kinds of remotes that come with plug in sockets so you can turn different things on and off but the remote will probably be different than the one you have being dedicated to this function.
28,384
There is a whole lot of information missing from the request for help. First, what sort of control is there presently for the awnings/drapes?
Note that I did not visit the original post, and so you need to clearly explain what the existing means of control are.
And the 13 220 remote control might be a model number or it may mean 13 systems powered by 220 volt mains.
So, please describe what controls each item to be controlled, is it a wired control connection, an RF link, ir an infra-red remote? With that information there can be some answers that are far more useful than guesses.
