HELP - Transformer with 3 single phase load and a connected capacitor
MH Ating
Joined Feb 9, 2016
4
Three single phase load: L1: 10KW, 0.8 pf, lagging; L2: 15KVA, 0.7pf, lagging; L3: 20kw, 0.6pf, lagging; are supplied through a 2400kv feeder whose impedance is 115+1.2j and 2400kv:240v transformer whose data were obtained from the following:
test: voltage current power
with high voltage winding open circuited 240V 1.066A 126.6W
with low voltage terminals short-circuited 57.5V 8.34A 284W
A capacitor whose impedance is -5j is also connected across the load. The voltage is maintained at 240v across the load.
Find: a) the sending end voltage using summation of voltage and summation of power.
b) the efficiency and voltage regulation of the transformer
----------------------------------------------------------------end of the problem
What would be the effect of the capacitor in the analysis of the circuit? would it be considered as normal impedance or what?
MrAl
Joined Jun 17, 2014
13,791
I think it would help if you created a schematic of your setup. This would help others understand your question better.
