The legs of many ceramic capacitors are rusted, on both side of the board. Only one appears to be weak when I gently move it back and forth.
Should I desolder them all and replace them? I am thinking of only replacing the weak one. For the rest, clean it up with tooth brush and some kind of chemical, then put some grease on it.
What would you advise to do? What chemical would work best for this? How about the grease?
Currently, it appears to work good. The board is for power, pedal, audio and USB out of a digital keyboard. I open this it because some keys don't work. I think it's highly likely just rubber contact issue.
Then I found this issue. Possibly they spilled something, or left it in a very cold garage.
