Help required with Potentiometer Circuit
35,196
The source voltage Vs is 10V.
If the voltage across the variable resistor VR1 is 9V,
what is the voltage V across the load?
ericgibbs
Joined Jan 29, 2010
21,578
hi 123,
Please check your question/drawing for accuracy, I believe it is incorrect.
Are you supposed to give the resistor value or the percentage rotation setting.?
E
