Help Powering a Delta PWM Fan
bertus
Joined Apr 5, 2008
22,983
The extra wire on the fan is an output to measure the speed.
Taken from the given info PDF, with some comments I made:
thescreensavers
Joined Jul 15, 2017
5
Bertus interesting, hmm reason why I posted is because the fan does not turn on when +12v is applied to it (red/black)
Which is why I was thinking it needed that pull up.
bertus
Joined Apr 5, 2008
22,983
What did you use for powersupply?
Did you use the correct polarity?
Black - and red +.
Blue F00 output (needs pull-up to see signal).
thescreensavers
Joined Jul 15, 2017
5
For quick initial testing(see if it spins) I am using a car battery (12v) Yes correct polarity was used, I ordered a replacement fan, mine may be defective, it should be here early next week.
Thanks for the help Bertus.
thescreensavers
Joined Jul 15, 2017
5
So I just looked at the fan I have and just relized its not the same exact one as the one on Digikey
It ends with AA03 not AF00
BFB0712HH-AA03 which that designation is not listed in that manual Ill have to dig deeper
