Help Please
skiddman
Joined Nov 7, 2012
26
I need help with this question
For the following values, Input = 125V RMS, Transformer output = 32 VAC and RLOAD = 200Ω,
Calculate the Peak Output Voltage, and DC
Average Voltage across the load. Calculate the current flow through the load, and the PIV rating required for the
diodes.
33,325
You need to show YOUR best attempt to solve YOUR problem. That will serve as the starting point for discussions aimed at steering you toward an answer.
