Help please.
Rock33y
Joined May 21, 2008
4
sorry don't really get your explanation..:confused: I was trying to solve this:
A 7 ohm, a 1 ohm, and a 10 ohm resistor are in series. This series combination is then in parallel with a 6 ohm resistor. The combination of four resistors is then in series with a 10.3 ohm resistor. A 20 V battery is used. What is the equivalent resistance?
If you can explain the above question, it'll be much appreciated
21,227
I prefer to answer your PM in the open forum so others may benefit.
Your explanation of the question was just fine. I don't know how much plainer my answer could have been. In the thread above there is a relationship for two resistors in parallel. This relationship can be applied recursively to any number of resistors in parallel. There is also the following relation
Rich (BB code):
For n resistors in parallel R1, R2, ..., Rn.
The total resistance Rt, is given by
1/Rt = 1/R1 + 1/R2 + ... + 1/Rn
If you really want to impress your friends at cocktail parties you can refer to this as adding conductances measured in mho which is ohm spelled backwards.
Another fun factoid is that in any parallel combination the total resistance is always strictly less than the smallest resistance on any branch.
