Help on what chip pin goes to which programmer pin.
GoofMaster
Joined Oct 1, 2020
Irving
Joined Jan 30, 2016
5,195
Not enough info on programmer to be 100% sure but best guess
Code:
CS#   <-   CS
SO    ->   MISO
WP#   <-   1
VSS   <-   GND
SI    <-   MOSI
SCLK  <-   CLK
HOLD# <-   2
VCC   <-   3.3v
Chip       Prog
Warning - Chip is 3.3v but programmer pins are 5v according to reviews.
CS polarity may need inverting
Prog pins 1, 2 & 3 are general purpose but use depends on programming s/w and no info to hand.
GoofMaster
Joined Oct 1, 2020
Code:
CS#   <-   CS
SO    ->   MISO
WP#   <-   1
VSS   <-   GND
SI    <-   MOSI
SCLK  <-   CLK
HOLD# <-   2
VCC   <-   3.3v
Chip       Prog
Thanks for the heads up!
GoofMaster
Joined Oct 1, 2020
Code:
CS#   <-   CS
SO    ->   MISO
WP#   <-   1
VSS   <-   GND
SI    <-   MOSI
SCLK  <-   CLK
HOLD# <-   2
VCC   <-   3.3v
Chip       Prog
Im flashing from linux-flashrom.
