HELP NooB Here: Select one compatible charger for ebike: 6 options below.
Greg D
Joined Nov 22, 2015
6
(Pick 1) Ebike Charger stolen and have six possible replacements but can not understand the ins n outs and all than techy stuff.
Can you help me select one of the bellow charger stats that I should purchase for this Ebike Charger that was stolen.
DETAILS BELOW OF STOLEN CHARGER THJAT CAME WITH E-BIKE:
LI_ION BATTERY CHARGER
MODEL: HP8204L3
INPUT: 115/230/VAC
60/50Hz 2.5/1.5A
OUTPUT: 36VDC/2A
OR
1 -New In Box HIGH POWER Lead-Acid Battery Charger
Model: HP8204B.
Input: 115/230VAC, 60/50Hz, 3/1.5A
Output:24VDC/4A
OR
nput Volt 100-240V
Output Volt 58.8V/14S (Li-ion cells 4.2v charge)
Charging current 3A
N.Weight : 1.139kg
Dimension(LxWxH) 19.5X9X5cm
OR
Item name: Electric Bike 48V 2.5A Lithium Battery Charger E-bike Scooter For Lifepo4 Li-ion Battery
· Input Voltage : 220V ( For Canada and USA country we will ship 110-220V Input Voltage)
· Output Voltage: 54.6V ( If need different output voltage, Please contact us, we can adjust on the charger. )
· Output Current : 2.5A
· Output Power : 136W
OR
48V/54.6V/2.5A Charger For 48V(13 cells) li-ion Battery Pack Scooter Ebike
mpatible Battery Type(s):
18650/CR123A
Electric Bike 48V 2.5A 16ah 20ah Lithium Battery Charger E-bike Scooter Lifepo4
OR
42V charger microphone head XLR connector for 36V NCM Lithium Li-ion ebike ebicycle battery wheelchair battery
42V Li-ion Battery Charger
Input: AC100-240V 47-63Hz 1.8A Max.
Output: 42V 1.8A---2.0A
OR
Electric Scooter DC36V 2A Power Charger Lifepo4 Li-ion Lithium Battery XLR3 E-BIKEElectric Bike
Note: The charger is suitable for 43.8 Volt Lifepo4 Li-ion Battery(12 series battery), is supported input AC 90-220V .Please make sure the
Suitable for 43.8 Volt Lifepo4 Li-ion Battery batteries(12 Series battery).
Casing material: plastic
Dimension(LxWxH):155mmx88mmx53mm
Input length:60cm
Output Length:62cm
OR
2A Charger For 36V Li-ion/Li-Po Battery in Plastic Case :
Input Voltage: 100-240V 50/60Hz
Output Voltage: 42V (for 10 series 36V Li-ion/Li-Po Battery use)
Output Current: 2A
Charging Mode: CC-CV
THANK YOU SO MUCH. I NEED THIS TO GET TO WORK AND SUCH. HAVE A GREAT DAY AND BLESSINGS.
-GREG D.
Feel free to contact me:
Havre a good one.
gregdiamondemail@g---mail.co--m
spinnaker
Joined Oct 29, 2009
7,830
Real simple. You need to know the power requirements of your eBike What are they?
If you have any warranty left on the bike then I am guessing it will not be covered unless you buy the manufacturer's charger.
Dodgydave
Joined Jun 22, 2012
11,307
As you said in your post..
Li-on 36V 2A charger is what you need, so get one that fits that spec, with the input voltage for your country.
Greg D
Joined Nov 22, 2015
6
UPDATED INFO: I read your replies and narrowed my work too this.
BIKE:
NC machined 350 watt motor, the Forza (BIKE) combines comfort with power, supplied by a 36 volt Lithium Ion battery,
M otor: Brushless 36 Volt Servo motor peak 700 watt / continuous
350 watt with planetary gears.
C ontroller: Custom build self diagnostic system with overload
protection at 20 amps and low voltage cut-off at 31.5
Volt to protect both motor and battery system.
Battery: State of the art - 36 Volt 10 Amp hour Lithium-Polymer
Complete with battery management circuit (BMS)
C harger: Automatic Smart charger, maximum charge time 5.5
hours (2 Amp)
MODEL: HP8204L3
INPUT: 115/230/VAC
60/50Hz 2.5/1.5A
OUTPUT: 36VDC/2A
Charger choice #1
Output Current: 2A
Charger choice #2
Electric Scooter DC36V 2A Power Charger Lifepo4 Li-ion Lithium Battery XLR3 E-BIKE Electric Bike
Input:AC 90- 240V, 50/60Hz
Output:DC 36V(43.8V, suitable for 12Series Lifepo4 Li-ion battery
Charger choice #3
Description
Charging time: 8~10hrs
Greg D
Joined Nov 22, 2015
6
I posted it below also:
NC machined 350 watt motor, the Forza combines comfort with power, supplied by a 36 volt Lithium Ion battery,
Speed: controlled by EZ Assist Factor speed dial, pedal activate
preset dial controller
hours (2 Amp)
I'm trying to learn this new language.
Greg D
Joined Nov 22, 2015
6
"Intelligent Charger Very Good Self-heat sinking Performance"
Anyone Know what this means? It costs 2-3 times as much. Dunno if worth it or not
Greg D
Joined Nov 22, 2015
6
http://www.ebay.com/itm/2A-Charger-...y-in-Plastic-Case-Ebike-Charger-/171335088439
2A Charger for 36V Li-ion/Li-Po Battery in Plastic Case Ebike Charger
Looks like this will fit?
I just found an E-bike store that sells a generic charger for double the one. Think there is any difference?
Thanks for any and all help. If you have questions on expedition hiking, & beginner or advanced snowboarding, or cool mountain towns in the USA I may be able to help ya... I guess you guys really dig this electrical stuff. I'm just trying to make my broken things work.
BReeves
Joined Nov 24, 2012
410
Either charger would do the job, just a matter of deciding if the difference in price is worth waiting on the one shipped from China. I have had good luck with ordering direct from China, but have to be careful in knowing what you are buying and be willing to wait a couple weeks or more for it to get to you.
