Help needed to identify a resistor
Rihie302302
Joined Aug 29, 2022
16
I need to identify this resistor and have asked in a few different shops but I’ve not been able to identify it, the colour bands are
brown/black/orange/orange
I brought some that claimed to have this colour code but they are tiny little ones and this one on the board is bigger in comparison…
Its the one labelled R69
djsfantasi
Joined Apr 11, 2010
9,237
Besides the resistance, specified by the color code, you need to specify the power rating of a resistor.
You’ve listed the colors backwards. The color code is orange, orange, black & brown. Brown is a color that specifies the tolerance. In this case ±1%. It is a 33Ω±1% resistor. Here is a calculator.
https://www.digikey.com/en/resource...ors/conversion-calculator-resistor-color-code
Now as to the power… this is why the resistors you bought with the same code we’re tiny. They were probably 1/8 watt. These look like 1 watt at least.
ericgibbs
Joined Jan 29, 2010
21,571
hi R302,
Agreed looks like a 33 Ohm say 1 Watt.
The ones you bought what are their value and how many did you buy.?
E
BTW: why do you think it is faulty.???
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
It's 33 ohms 1% tolerance. What did the shops say?
You read the color code backwards. Orange isn't a valid color for the 4th band.
Rihie302302
Joined Aug 29, 2022
16
Thank you for your help, yeah I used the calculator and came up with 33 Ohms but couldn’t understand why they came so tiny, thank you for explaining the difference in wattage…
ericgibbs
Joined Jan 29, 2010
21,571
hi R,
If you need to, you could connect two in parallel and another two parallel, connect those pairs in series, that will give you a 33R at 1Watt.
Do you follow OK.?
E
Added image.
