Help needed in improving intermittent buzzer circuit
Crea
Joined Dec 11, 2017
9
Good afternoon to all,
May I ask for help in improving this circuit? The function is that it will beep 5 times when the switch is pressed but there are times that the buzzer will beep immediately without pressing the switch yet.
Any suggestions are welcome and thank you.
ericgibbs
Joined Jan 29, 2010
21,572
hi,
No problem, will move it for you.
On your circuit add a 100uF and 100nF capacitor on the 12v supply lines to the 555.
Lets know how it goes.
E
ericgibbs
Joined Jan 29, 2010
21,572
hi,
The two caps are in parallel across 12V to 0V.
E
Update:
Electrical noise on the 12V rail can cause erratic triggering of the 555.
The purpose of the caps is to reduce the electrical noise on the rails to a level that does not cause a false trigger.
Crea
Joined Dec 11, 2017
9
Update:
Sir may I ask why two capacitors in parallel instead of 1? Curiosity speaks if you don't mind. Thanks a lot.
ericgibbs
Joined Jan 29, 2010
21,572
hi,
The higher value cap, 100uF can supply current to the 555, if the 12v drops momentarily.
The lower cap 100nF has a lower impedance at higher frequencies than the 100uF, so 'electrical noise' , fast spikes on the 12v are shunted to 0v/gnd.
Thats a very basic explanation, if you want to know in greater detail, ask.?
E
