Hi All,
Need ideas in designing triggering circuit....
basic idea:
triggering int when the switch is closed........were the switch is connected to 240V AC, 60Hz supply......All I need is a pulse at the int pin when switched ON.
Felt using transformer could increase the size of the board......Is there a way to reduce the size of the board using optocouplers or something else if so how?
I found an AC switch detector .....follow link
http://www.st.com/stonline/products/...592/stcc08.pdf
will this useful for achieving the above idea?
all i need is pulse to INT pin(PIC16F628A) when AC switch is closed .........
Thanks to all in advance
basic idea:
