Help me with this water levels in a tank project please
Agezsttp
Joined Jun 13, 2020
Has an electronics engineer, you are required to come up with a circuit that controls the
water levels in a tank so that it saves water as well as powers when a tank is filled up by
cutting the power supply to the water pump. Write a project proposal that will explain the
working of the circuit?
Ramussons
Joined May 3, 2013
1,572
Before coming to a circuit, can you visualise what has to happen?
Let me give you a start.
* Tank becomes full - stop pump.
Alec_t
Joined Sep 17, 2013
15,156
Welcome to AAC!
Consider how you will detect if the tank is full, or is nearly empty and needs filling.
Research the power requirements of the pump.
Show us your work so far on this project.
