Help me in calculating base resistance for transistor
rahulb
Joined Jun 5, 2019
44
I am making a circuit for a led chaser. the leds should glow one by one.
I am testing the circuit with one led for each transistor later I will add array of leds to each transistor.
I want the base resistor value to make the transistor turn on. Leds will have resistors to limit current to them.
Problem is : first led is glowing continuously, second one is not glowing and third one is glowing dim but continuously. they should glow and turn off one by one.
Voltage used is : 12v DC
datasheet link : https://bit.ly/32yOfpg
thanks
Dodgydave
Joined Jun 22, 2012
11,395
Could be the clock speed too fast, put a led on the output of the 555 timer to see if it's working,.. Your circuit looks ok.
Picbuster
Joined Dec 2, 2013
1,058
thanks
Remove IC1 and pulse 4017N pin 14 using a button.
next step is to measure the 555 out when installed (speed).
Personally I prefer fets above transistors when switching things. ( low internal resistance and a voltage driven input)
Picbuster
