help me identify one resistance....
UnnamedUser159
Joined May 3, 2016
501
the problem is that i see color Black at first or last position and there is no color black on first or last position in calculators...
the pictures are not so bad. the colors are : Black red Purple silver Gold.
i now saw that the resistance is kinda broken. Are they failed that way or they only look burnt?
jpanhalt
Joined Jan 18, 2008
11,087
In my experience, the color bands black, brown, and violet can look the same without careful examination in bright sunlight. Of those, I find violet and brown very hard to differentiate even with new components. True, a first band of "black" is indeed unusual and unexpected. That is why it is often useful to use a meter to tell what it is.
dendad
Joined Feb 20, 2016
4,637
Ir you have not measured it, how do you know it is not an inductor? those colours are consistent with the markings of an inductor and they do come in that sort of package some times.
UnnamedUser159
Joined May 3, 2016
501
The reason i am shocked is that if that is not black i should be really daltonist :D
It`s desoldered from point labeled with R.
My esr meter does show 115.3 K and symbols are 1-Resistance-3
The idea ...
I am trying to find the "bad and faulty" from one power switch unit
I dont find schematic so i should read color codes to understand the value and then compare with measured.
Here`s picture of that crack
dendad
Joined Feb 20, 2016
4,637
The problem is resistors do not have the first band as black. Inductors do.
Is there any place where there is another the same?
That crack in the body of the part will render any measurement invalid.
What is it from (brand and model)? Do you have any chance of getting a schematic?
More info may help. As it is, there is nothing more can be done as you have not given enough info. And just because the board has an "R" label, it may not be a resistor. The board may have been designed for a decoupling resistor but production could have found an inductor gave better results. Can you trace out the circuit or post some pictures of the board?
jpanhalt
Joined Jan 18, 2008
11,087
Uncommon, but not non-existent. Here is a 5 mohm 1% resistor from Ohmite/Digikey:
On searching for examples, some calculators omit black from the first band. Others include black as an option,
dendad
Joined Feb 20, 2016
4,637
Well, That is a new one for me. So you just take off a decimal places for the blacks? I'm still unsure how to read that to get 5Mohms.
I wonder why the manufacturer decided to go with their own "standard"
That is the thing about standards. They are good, that is why we have so many ;)
So, the original resistor in question may be 0.027R ???
jpanhalt
Joined Jan 18, 2008
11,087
For that particular series, Ohmite uses a white multiplier band to mean 10^-3 (http://www.ohmite.com/assets/docs/res_wl.pdf?r=false). I guess the theory is that one is unlikely to confuse a gigaohm resistor with a milliohm one. And if you did, you might get a real surprise.
The TS's resistor is may well not be Ohmite. In fact it does not look like the Ohmite examples. However, if the black band for some reason is meant as a leading zero, one could read its value as 0.26 ohm too -- the multiplier band certainly looks like silver instead of white..
