Judging by the limited product info on the manufacturer's web-site it's questionable if even 380mA is possible. The only reference to current that I could see was a graph with the figure '22mA' on it. How practicable would it be to connect patches in parallel and series to achieve the required current/voltage for an inverter? Indeed, how does one make connections to the stuff?
Could you put things inside the lining?
