Help me design a gate open beeper
spiral8
Joined Aug 5, 2024
23
OK, here's my schematic (Less resistor values and cap values) OH! The battery is 9V.
Thanks for going the extra mile to post your info!
So you're using the LM385 as a time delay to then sound the continuous alarm?
I would like to have a beeper rather than a continuous alarm for 1) intermittent beeping would be less annoying and 2) less power used to sound the buzzer.
Thanks.
spiral8
Joined Aug 5, 2024
23
It would seem that a continuous sounding horn would be annoying, both to you and any neighbors.
You could add a timer circuit to activate the horn for a short beep every few seconds.
Agree. Short beeps would be less annoying and also reduce the on time of the buzzer to save battery power.
Thanks.
spiral8
Joined Aug 5, 2024
23
I have some of these. Automotive squeaker. They might pull too much power but it is place to look. There is also the seat belt not connected squeaker. Place these at head high and you will hear them.
I've tested my hearing using online tone generators. 400Hz - 1KHz is the best frequency range for me. I assume that this small unit's frequency is probably in the 2500+ Hz range. Too high for me. Thanks
spiral8
Joined Aug 5, 2024
23
LOL; yes! My neighbor had an annoying barking dog. He put a shock collar on him. He quickly learned to be quiet when wearing the collar. But it was recommended not to put the collar on the dog for more than 12 hours at a time. So the dog learned that when not wearing the collar it was permission to bark. And this dog would aimlessly bark at nothing. Just felt the need to express himself. THEN other dogs in the neighborhood would hear him howling and they'd start. Which would egg him on.
LOL ... Our dog is a Border Collie and she's very smart. She would learn that trick in a heartbeat.:)
Perhaps a more expensive route to go would be to use a bluetooth or Wi-Fi transmitter that would signal you on your phone when the gate was open. No need for audible alarms or anything else that the dog would learn from.
I don't carry my mobile phone while I'm at home. Just rely on our landline phones that ring throughout our house. Old school .
spiral8
Joined Aug 5, 2024
23
Another option Here
That unit would be perfect as long as it doesn't work like a 400Hz buzzer that I bought from Amazon. The Amazon buzzer was barely audible when not mounted. It required firm mounting to a surface that can vibrate to act like a speaker. Then the sound level was satisfactory but to mount it on a suitable surface was the problem.
I'll try to do further research on the unit you linked to. Thanks.
Tonyr1084
Joined Sep 24, 2015
9,744
LM385 ?
Do you mean a LM358 ?
Will have to check into that. You could be right. Probably are.
Thanks.
Gave you this simply as food for thought.
27,960
Once again I am going to suggest using an "off the shelf" kid's type bicycle horn. They come in a weather resistant package that also holds the batteries. Only the switch is external, connected to the two wire cable that is part of the package.
spiral8
Joined Aug 5, 2024
23
A bicycle horn as you describe would fit the bill nicely if it is a low frequency horn.
I've been searching on Amazon and the electronic bicycle horns that have video reviews appear to use piezo buzzers so are rather high in frequency. Many use two button batteries which seem rather underpowered. And some use rechargeable battery which would not work for my situation.
If anyone knows of a low frequency electronic bicycle horn, please post a link.
Thanks for the nice suggestion.
27,960
I was thinking more in the line of what I have seen in stores. And I am NEVER impressed by what the artificial intelligence of online shopping software thinks I should be interested in.
The bike horns that I am thinking of all have electromagnetic buzzer arrangements driving a metallic diaphram. Of course it may be that those are a bit obsolete. Probably what I am thinking about would be available at an older bicycle shop, maybe on a shelf in the back room, so that you would need to ask about it.
spiral8
Joined Aug 5, 2024
23
If I can find an electronic bike horn in the 400 - 1K Hz frequency range, that would save me from a lot of work. I'll keep looking. Thanks for the nice suggestion.
BobTPH
Joined Jun 5, 2013
11,609
I asked google what was the frequency of a car horn. This was a part of the AI response:
The frequency of a car horn can range from 200–500 Hz, but can also be as high as 2400 Hz. The frequency of a horn is often related to the size of the vehicle. For example, a red car moving west on a road may produce a loud sound with a frequency of 700 Hz.
Who knew the color of the car and direction of travel had anything to do with it!
27,960
It has been a long time since an answer has made me laugh this much!! I was not aware of the vehicle color affecting the horn output. Thanks to AI we can now be aware of this.
BobTPH
Joined Jun 5, 2013
11,609
I suspected the AI fail I showed in post #36 was a result of it misinterpreting a text about doppler shift as saying something about the frequency of a car horn. So I searched, and found this text:
Question
A red car moving west on some road is creating a loud sound with a frequency of 700Hz. A blue car is also travelling west along the same road. A person in the blue car hears the loud sound from the red car.
From the following list of frequencies, what possible frequency or frequencies might the person in the blue car hear?
1) 710 Hz
2) 700 Hz
3) 690 Hz
Tonyr1084
Joined Sep 24, 2015
9,744
Which car is traveling faster? And how much faster? Are they approaching from behind or driving away from in front of the other car?
Tonyr1084
Joined Sep 24, 2015
9,744
And aren't we just a bit off topic ? ? ?
Low frequency alarm, beeper or car horn intermittent to alert the home owner the gate is still open. Seems the biggest problem to solve is the frequency of the alert signal. Maybe paint it a different color ? ? ?
