Help me analyze this EQ circuit
rpschultz
Joined Nov 23, 2022
851
The below circuit is from the Fishman Loudbox Mini acoustic guitar amplifier, the tone controls portion. The low and mid are fixed frequency peaking EQ and the High is a shelf. I understand the low and mid but can't figure out the high:
Low:
f = 1/(2 PI sqrt(R14 R15 C11 C12)) = 53 Hz
Mid:
f = 1/(2 PI sqrt(R16 R17 C13 C14)) = 766 Hz
(I'm reasonably sure this is right since Fishman has told me the Mid to be 750 hz).
High:
I thought it was f = 1/(2 PI C15 R18) = 4200 Hz, but that seems too low (maybe not). Is U2A involved with the High, or is that an output buffer?
Thanks.
Jony130
Joined Feb 17, 2009
5,599
Your calculations look good.
The U2C and U2D are nothing more than a simulated inductor circuit.
L1 = 3.3kΩ*3.3kΩ*820nF = 8.9H and L2 = 3.3kΩ*3.3kΩ*120nF = 1.3Hz.
Thus, together with a series capacitor (C11 and C13) creates a series resonant tank circuit. And resonance frequency of F = 1/( 2Π√(LC) ).
The maximum "boost" will be Av_max = 1 + 20kΩ/( 3.3kΩ+ 3.3kΩ) = 4 V/V = 12dB.
But for the high frequency, we have a simple RC circuit. And if you set the high to max gain it will be around 1+20Ωk/5.6kΩ = 4.6 V/V = 13dB for the signal frequency larger than F = 0.16/(6.8nF * 5.6kΩ) = 4.2KHz
rpschultz
Joined Nov 23, 2022
851
Huh, OK. Seemed like 4200 Hz was low, but I guess not. That's a fair number (3-1/2) octaves above high E, so probably a good spot for it. Thanks for the confirmation.
rpschultz
Joined Nov 23, 2022
851
So in this circuit, with the switch is set to SHELVING (C2 bypassed). If I want a fixed frequency by removing VR1, do I need U1? Because in the original post, the HIGH only had 1 op amp instead of 2, it was a simple RC circuit with only gain and a fixed frequency of 4200... but I think that is a LPF (not shelving). So if I want a shelving Low knob, then it needs an op amp as seen below. Right? You can have passive LPF and HPF, but shelving filters need an op amp?
Jony130
Joined Feb 17, 2009
5,599
I understand how Q and bandwidth are related. I can simulate this in Eagle and get the same frequency. Anyone know the formula for the Q based on R1, R2, C1, C2?
Your simulated inductor circuit will have this equivalent circuit.
From this equivalent circuit we can see why we want to have R1 >> R2.
As for the quality factor of a series resonance circuit in will be Q ≈ 1/R1 * √(L/C1)
rpschultz
Joined Nov 23, 2022
851
OK, I think I figured it out. Based on the below diagram and corresponding AMZ calculator.
fo = 1/2/Pi/sqrt(R1 R2 C1 C2)
Q = 2 Pi fo R1 C2
BW (Hz) = fo/Q -> bandwidth
Then this link helps figure out the BW in Octaves.
Simplest one: N (BW in octaves) = 2/Ln(2)*asinh(1/2/Q)
The bandwidth (BW) is based on -3db from the center frequency fo, f1 and f2 on either side of the center. It's interesting because it's not equal frequencies on either side due to the nature of how octaves work, although it's close.
(I solved this equation in Mathematic)
f1 = (sqrt(BW^2+4*fo^2)+BW)/2
f2 = (sqrt(BW^2+4*fo^2)-BW)/2
So if you pull up the default values for that AMZ, you get:
R1 = 68k
R2 = 1k2
C1 = 560n
C2 = 56n
fo = 99.54 Hz
Q = 2.38
Then from further calcs:
N = .6017 (octaves)
f1 = 80.765 Hz
f2 = 122.56 Hz
f average = 101.663 -> which is a little higher than fo.
rpschultz
Joined Nov 23, 2022
851
The schematic in #13 is vague on the ground. Here's how I modeled it to get a peak band EQ:
The cursor is at -3db from fo, 130 Hz is close to the AMZ calculation.
Audioguru again
Joined Oct 21, 2019
6,826
You are wrongly mixing the biasing of opamps that usually have a power supply with the usual V+, 0V and V- with a single positive supply and 0V. Then the output of the opamps are rectified positive pulses instead of linear AC audio.
Most of us use the free simulation program LTspice.
rpschultz
Joined Nov 23, 2022
851
So the voltage source on the right is DC. It says DC 9 AC 0.
The voltage source on the left is AC, says DC 0 AC 1. This represents the frequency input for simulation.
