Help to analyze a circuit
Alekyakoi
Joined Feb 9, 2017
7
Hi everyone,
I would like to understand a circuit. It is supposed to be a driver for a coil that oscillate at a freq around 1kHz and my goal is to be able to fix the value of the inductor, capacitor and resistor to calculate the frequency of the oscillation.
I did some search about oscillator circuits but none of the circuit I saw look like this one (collpits, harley ect...).
Is someone is able to explain how this works? Let me know also if the particular circuit has a name.
Papabravo
Joined Feb 24, 2006
22,111
I have my doubts that you can find parts to make this work. I didn't think resistors could be easily fabricated on an integrated circuit prior to the use of MOS transistors. Do you have a part number or a datasheet?
28,322
It looks a bit like a series tuned Colpitts oscillator, but the connection between the capacitor and the inductor should not connect to the positive supply line. It also looks a bit like the Vackar oscillator circuit.
