I'm trying to identify the IC inside the remote control for my DuneHD media player.
It's a 20-pin surface-mount package with no identifying marks.
I've discovered the following so far:
It uses the NEC code scheme;
Pin 6 is the output to the IR LED;
Pin 3 is the output to the "sending signal" LED;
Pins 17 & 18 connector to a 3.64MHz ceramic resonator.
Attached are some photos of the item in question.
If anyone could give me some pointers as to what IC it might be, it would be very helpful
