help identifying diode in a switch mode power supply board (for LED TV)
electron_jj
Joined Aug 28, 2021
14
Hi everyone, I am new to this forum. I would like to seek help on identifying a tiny diode in a switch mode power supply board in a Panasonic LED TV. The diode (D407 on the circuit board) has been circled in yellow in the attached photo. I have also attached the portion of the schematic with D407 diode highlighted in green. Unfortunately, this schematic diagram which I have found on the web does not provide any details on the components. The diagram only shows the circuits with no values stated for the components.
I have desoldered the diode out of the circuit and measured it with DMM using diode mode and the voltage value is around 0.173 which I think it unusually low and may be defective. The reverse reads OL. The markings on the diode is IK4 6A. Many thanks for your help!
camerart
Joined Feb 25, 2013
3,842
Hi E,
It could be this?
https://www.alibaba.com/product-detail/6A10-Rectifier-diode-6A-1000V-electronic_60743498896.html
C.
Ian0
Joined Aug 7, 2020
13,164
It would appear that the control IC is a Sanken STR-A6051M, 22W switched mode IC. The diode in question is across the current sense resistor (R405). It doesn't appear in any of the application circuits, which implies that it would be perfectly OK without it.
22W output would suggest an average current of 67mA through R405 for a 230V supply, so a peak current of about 0.4A.
The voltage across the current sense resistor should not exceed 1V. It's probably there as a protection diode as the current sense input might not like a reverse bias, and there may be some oscillation due to the snubber cap (C405) and inductor (L402)
I think therefore it is probably a 30V 1A schottky, which would have a forward volt drop of about 0.15V, exactly as you measured.
electron_jj
Joined Aug 28, 2021
14
Thanks for the detailed analysis! I got a reply from another forum who also concluded that the diode is a schottky. But my only reservation is that the schematic diagram symbol for the diode (R405) is only showing the normal diode symbol and not the schottky diode symbol. I am a beginner at electronics and just starting to learn the basics as I am trying to repair the LED TV power supply board. I have checked most of the diodes and capacitors on the board and cannot find any faults. I am now kind of stuck not knowing what else to check. Do you have any suggestions as to any books or guides which may be useful for LED TV power supply board repairs? Many thanks!
Ian0
Joined Aug 7, 2020
13,164
electron_jj
Joined Aug 28, 2021
14
