I'm going to go off in another direction and say that it is probably a polyswitch. Nominal resistance 3.9 ohms. used to limit the inrush current to the rectifier and capacitors on switch on. If this has failed, which is what it looks like and your fuse is blowing, then there is short circuit in the rectifier or capacitors of the SMPS.
Replace the polyswitch with a 240V incandescent bulb (say 40-60W) and if the bulb glows you know you have a short circuit, Track it down from there.
Element14 or RS should be able to supply a replacement polyswitch
