I did place a load on it. Near as I can figure, it is not regulated as it does drop with varying load. I am sure it will scale to 6V at full load.Have you tried measuring the voltage output under a load? I'm guessing at 5 amps the max output might be at around 6 volts but is it regulated or suppose to be regulated?
SG
