Help ID an old capacitor?
skanker
Joined Jan 17, 2018
13
Hi Folks
Im hoping someone can give some advice regarding the value of the large grey/orange capacitor in the image attached?
I accidentally broke one whilst swapping the IC's during a repair and i have no idea what to replace it with, any advice is much appreciated
Cheers!
skanker
Joined Jan 17, 2018
13
I've attached an image of the one, i need to replace. It's not fully legible sadly but it looks like one of the following: nTS, nT5, n15 nI5
LesJones
Joined Jan 8, 2017
4,511
If I am readin the number on it correctly which I think is n15 then I think it is a 150 pF (0.15 nF) ceramic capacitor. (I have some that look the same marked n10 which measure as 100 pF.)
Edit. I have just seen the picture in post #5 which confirms it is n15.
Les.
bertus
Joined Apr 5, 2008
22,929
Do I see an organge top on the capacitor?
That color orange means a temperature coefficient of 150 negative.
See table 7 and 8 of the attached PDF.
skanker
Joined Jan 17, 2018
13
Thats a great resource, thanks for sharing Bertus. I'd already ordered the one in the image attached which has a black band and according to the docs you gave a temperature coefficient of 0 × 10−6/K
I have to be honest and say this means nothing to me tho, Im now looking for a like for like but they seem to be hard to find.
In your experience, will the one ordered be a suitable replacement?
The unit in question is a MK3 BFE Filtek Eq circa 1975
skanker
Joined Jan 17, 2018
13
It could also be a capacitor from the 632 series.
Have a look at the following PDF from page 130.
https://archive.org/details/MullardBook3Part1ComponentsMarch1981
Thanks, thats interesting and confusing at the same time!
I'm ok repairing my kit when it's a like for like replacement but my experience is novice level at best so when i have issues finding a part i struggle to decide what replacement is best. Im overly cautious knowing my lack of knowledge could easily lead me to cause more damage.
Anyhow, looks like i've bagged some in the link below. I've looked into the 632 series mentioned above and have found nothing online at all. Will do more searching tomorrow.
https://www.ebay.co.uk/itm/30x-Kera...682196?hash=item2a7782b914:g:GYsAAOSwUsJYV70X
skanker
Joined Jan 17, 2018
13
Hi guys
I had such good advice last time i asked i have a couple of more parts to ID if you can please take the time to look.
They are two multicoloured capacitors (green/grey/blue) and (Pink/Yellow/purple) with no written markings and are on the same unit my last question was related too.
I've look online and cant find anything similar.
These are the only parts i've not managed to ID so any info is much appreciated.
Cheers!
skanker
Joined Jan 17, 2018
13
Back again folks regarding this project as i'm struggling to find replacements for these two caps. Can i ask what you guys would decide on if you were in my position please?
The ones i ordered have shown up and are so small compared to whats already there and look nothing like them either so they cant be right. Do they have to be tantulum replacements or not and how important is the voltage value when replacing a part like this?
First one is YELLOW-PURPLE-WHITE-PINK 470pF 35V
Second one is BLUE-GREY-BLACK-GREEN 6800pF 16V
LesJones
Joined Jan 8, 2017
4,511
I would dissagree on those values. I think the basic unit is uF
So YELLOW-PURPLE-WHITE-PINK is 47 x 0.1 = 4.7uF (I agree on the voltage rating.)
BLUE-GREY-BLACK-GREEN is 68 x 1 = 68uF (I agree on the voltage rating.)
One of these should do for the 4.7uF
One of these should do for the 68uF
Les.
