Help for Oscillator that generates a CK signal with a frequency of 1kHz and Duty Cycle 30%
monika.duccoli
Joined Jan 12, 2024
72
Hello I would like to realise an oscillator that generates a CK signal with a frequency of 1kHz and Duty Cycle 30%, I can use a NE555. Because I wanted to realise it as a stable vibrator, but among the specifications I read CheDuty cycle = tH / period > 50%
Alec_t
Joined Sep 17, 2013
15,115
The method in post #2 for obtaining a duty cycle <50% is the text-book way of doing it. There is at least one other method, which a bit of Googling on your part should reveal.
Ian0
Joined Aug 7, 2020
13,126
What are your limits of error? How close to 1kHz does it need to be? How close to 30% duty cycle?
You would have to pay a lot of money for the capacitor if you want ±1%. it would be cheaper to use a crystal oscillator and divide it down.
However, if ±10% is good enough, then the 555 will do the job.
monika.duccoli
Joined Jan 12, 2024
72
Now I try to do the simulation with a duty cycle of 70% and then use an inverting, after having created an oscillator that generates a CK signal with a frequency of 1kHz and Duty Cycle 30% I have to proceed with a circuit that for each rising edge of the signal CK output from the oscillator generates a negative pulse (1) with duration Tw1=25µs after a delay time TEL=125µs.
To create this circuit I had thought of first using a capacitance obtaining a delay time equal to 125µs and then using the OR, I sized the resistance and the capacitance in such a way as to have a pulse duration equal to 25µs
Do you think this could be a good idea?
monika.duccoli
Joined Jan 12, 2024
72
Ho una tolleranza +/- 5% sulla frequenza di oscillazione e sulla durata degli impulsi.
Mod translate, please use English text.
I have a +/- 5% tolerance on the oscillation frequency and pulse duration.
Ian0
Joined Aug 7, 2020
13,126
The accuracy of the threshold voltage on a logic gate is not good. You would not achieve your 5% accuracy.
Ian0
Joined Aug 7, 2020
13,126
The tolerance on the threshold voltages of a 555 is ±6%, even with 1% tolerance capacitors and resistors you would not achieve your target without a preset to adjust the tiMing.
monika.duccoli
Joined Jan 12, 2024
72
so you recommend adding a trimmer (adjustable potentiometer) to your setup. This allows you to manually calibrate the frequency and duty cycle. You can use a trimmer to adjust the resistance in the circuit to get the specifications you want?
monika.duccoli
Joined Jan 12, 2024
72
I have to create an oscillator that generates a CK signal with a frequency of 1kHz and Duty Cycle 30% and a circuit that for each rising edge of the CK signal output from the oscillator generates a negative pulse (1) of duration
Tw1=25μs after a delay time TEL=125μs. Assume a tolerance of +/- 5% on the oscillation frequency and pulse duration.
to obtain a timed delay of 125µs I thought of using a monostable 555, but it seems too expensive to me, I wanted to use something simpler
38,458
Don't understand why you need a 30% duty-cycle of a 1kHz signal if you are generating such short pulses.
What does the duty-cycle have to do with anything?
