help for my assingment ?
ubeyd
Joined Nov 30, 2014
4
Hi
i am a student of computer engineering but my college so insisted to teach me physics :p
so i have an assignment..i think questions are pretty easy but i am stuck at few points
so at first question i know how to find the voltage drops if there is only voltage source but there are 2 in this question so any tips ?
and for the second part, i am familliar with KVL but again 2 voltage source so i am not sure how it effects the answer.
about the second question i take any advice cuz i am not familliar with Thevenin equivalent yet
thanks in advance
Jony130
Joined Feb 17, 2009
5,598
Q1 - simply try applying KVL around the loop you have in the circuit.
Q2 - use a circuit theory and find Vab voltage, and Vab = Vth, next short A and B together and solve for Isc.
And finally Rth = Vth/Isc.
For example we could find Vth by using the superposition for I current.
I = 10V/(2000 + 200) - 9*I * 200/(2000 +200)
I = 10/2.2 - 9*I*0.2/2.2
2.2*I = 10 - 9*I*0.2
2.2*I = 10 - 1.8*I
4*I = 10
I = 10/4
I = 2.5 and this result is in mA
I = 2.5mA
So Vab = Vth = 10V - 2.5mA*2000 = 10V - 5V = 5V
http://forum.allaboutcircuits.com/threads/thevenins-theorem.102247/#post-771380
dalam
Joined Aug 9, 2014
58
2.2*I = 10 - 1.8*I
4*I = 10
I = 10/4
I = 2.5mA
In the circuit that you uploaded if I take Vb as a reference node then Va becomes zero.
I1=0. And I=10/2000. Isc= 10*I=1/20.
What is wrong in this analysis?
dalam
Joined Aug 9, 2014
58
V/2000+V/200=9I+1
I=-V/2000
So, V/2000+10V/2000=-90V/2000+1
101V/2000=1
V=2000/101
V/I(test source=1A)=Rth=2000/101
dalam
Joined Aug 9, 2014
58
Nothing is wrong, Isc is equal to 1/20 = 50mA
So tell me why you think that your analysis is wrong ?
You got I =2.5mA that's why. Moreover I did not understand how did you use superposition here.
Can you please testify the answer that I posted in the post above and the approach as well.
Thanks in advance.
Jony130
Joined Feb 17, 2009
5,598
V/2000+V/200=9I+1
I=-V/2000
101V/2000=1
V=2000/101
Please check your math again because the correct answer for V is 100V
And Rth = 100V/1A = 100Ohm
http://www.wolframalpha.com/input/?i=V/2000 +V/200=-9V/2000 +1
I got the same result using different approach.
Vth = 5V and Isc = 50mA so Rth= 5V/50mA = 100 Ohm
Where I wrote that Isc is 2.5mA ??
In my post 5 I solve for Vth, but I use superposition to find I current first.
What you do not understand. I simply use a superposition to find "I" current
First I remove current controlled current source from the circuit.
So I' = 10V/(2000 + 200)
Next I remove 10V voltage source and use a current divide rule.
I'' = - 9*I * 200/(2000 +200)
and finally
I = I' + I'' = 10V/(2000 + 200) - 9*I * 200/(2000 +200)
Also please read this
http://forum.allaboutcircuits.com/t...rrent-and-voltage-sources.101488/#post-764893
dalam
Joined Aug 9, 2014
58
Thanks a lot. My bad, I wrote -90V/2000 instead of -9V/2000. And thanks for explaining about superposition. I was not sure weather dependent sources can also be analysed using superposition.
32,876
Yes they can. As long as the circuit is linear, superposition applies (in fact, that is the definition of a linear system).
Imagine that you have a current I0 that is a function of three different independent sources:
I0 = I1 + I2 + I3
Now imagine you have a dependent source that is
Ix = kI0
Well, that works out to
Ix = k(I1 + I2 + I3) = kI1 + kI2 + kI3
and so we see that it is the sum of the currents that are output by the dependent source in response to the three independent sources individually.
dalam
Joined Aug 9, 2014
58
I0 = I1 + I2 + I3
Ix = kI0
Thank you, WBahn for helping me out.
