Help for Microcontroller isolation!
lmarklar
Joined Apr 23, 2015
24
He's done it so much he just doesn't say the steps that he does in his head automatically :p
Rds@5v * Load Amperage = Voltage Drop across FET
Voltage Drop * Load Amperage = Wattage the FET needs to dissipate
http://www.mouser.com/Search/Produc...505virtualkey57370000virtualkey942-AUIRLI2505
It's a bit expensive but has a crazy low Rds on. For your application with a 5v gate source
0.01 ohms * 5v = 0.05 voltage drop across
0.05v * 5a = .25w
Should be able to run that without a heat sink, but I would still recommend at least a small one to help out.
I just had that datasheet handy because I happened to be getting a couple for a high amperage job. You can probably find even better than that if you only need to go up to 5a
joeyd999
Joined Jun 6, 2011
6,301
joeyd999
Joined Jun 6, 2011
6,301
...Should be able to run that without a heat sink, but I would still recommend at least a small one to help out.
To help what out?
The junction to case thermal resistance is 65C/watt. 1/4 watt power dissipation will lead to a junction temperature increase of ~16C over ambient. Maximum junction temperature is 175C. Therefore, this part could be run at 1/4W at up to 159C ambient without a heatsink with no problems.
Heat sink is definitely not required.
