Help for Microcontroller isolation!
elborgy
Joined Nov 20, 2012
9
I'm working on a project that controls 12V 5A heater with pic Microcontroller, I need to control it without relay. So I designed a circuit using optocoupler (PC817) and two power sources (Vcc 5V for PIC, Vpp 12V for heater) for isolation, I need to know if this circuit will work good with this heater or not and if there is another idea for isolation?
Thanks in advance,
Borgy
38,506
It's unlikely that you need isolation. Just run a separate ground back to the power supply for the 12V heater current (transistor emitter) and tie the two grounds together at the power supplies.
Note that you need to provide 500mA to the base of the transistor to properly switch a 5A load. The opto isolator or the PIC cannot provide that.
It might be better to use a MOSFET instead of a BJT to switch the load since they can be controlled with a voltage.
Reloadron
Joined Jan 15, 2015
7,889
I also see no need for isolation. However, you may want to reflect in your drawing that the transistor MJ11016 is in fact a Darlington and not a standard NPN transistor as drawn.
Ron
NorthGuy
Joined Jun 28, 2014
611
Why without relay? Using relay would save at least 5-7% of energy and would eleminate heat sinks. Not to mention, it would automatically provide isolation, so that bad swings on the heater's ground wouldn't affect your MCU.
Reloadron
Joined Jan 15, 2015
7,889
If you run with the first drawing which will work just make sure the MOSFET used is a logic level MOSFET because the gate voltage will be low. For that reason I would use the second circuit allowing the 5 volts to drive the transistor to turn on the MOSFET. I would use a common 2N3904 or 2N3906 transistor.
Ron
lmarklar
Joined Apr 23, 2015
24
The IRF634 won't work in the first drawing. as MaxHeadRoom said, it's Vgs(th) is 2 - 4v and actual Vgs is 10v. You would need to use the second drawing for that guy as it will provide enough power to ensure you are fully switched. (I just went through the same thing with the wrong switching power because I misread the datasheet)
SgtWookie
Joined Jul 17, 2007
22,230
The IRF634 is a poor choice. It's not a logic-level MOSFET, which complicates the gate drive requirements. It's rated for far higher Vds (voltage from drain to source) than required, and it's Rds(on) is significantly higher than it could be.
Take a look at something like an IRLU7807:
http://www.digikey.com/product-detail/en/IRLU7807ZPBF/IRLU7807ZPBF-ND/811176
Logic level, Vdss=30, rated for 43A continuous (if you can keep it's junction temp down), Rds(on) is 13.8m Ohms when Vds is 10v, max of 18.2m Ohms (0.0182 Ohms) when Vds = 4.5v and Id=12A.
SgtWookie
Joined Jul 17, 2007
22,230
With Vds=5v, Rds(on) = 0.18 Ohms; so with a drain current of 5A, you will have 5A x 0.18 Ohms = 0.9V dropped across the MOSFET, with a resulting 4.5 Watts of power dissipation in the MOSFET. You will definitely need a heatsink on it, and probably a fan blowing air on the heatsink.
On the other hand, if you used the MOSFET that I suggested, you would have 69mW power dissipation in the MOSFET, and no heatsink required.
elborgy
Joined Nov 20, 2012
9
So what can i do I didn't find IRLU7807 , i need something available to switch, can you please help me SgtWookie for that,, i tried it and yes it need cooling,,
SgtWookie
Joined Jul 17, 2007
22,230
I already helped you with that - I gave you an example part# and where you could buy it - if you are in the States, that is. I have no idea what else you might have available where you are, or even where in the world you are, as you have not mentioned that as of yet.
If you must use what you have available wherever you are, then you will need to do research on what you have. Make a list of your available power MOSFETs, and then go online and find their datasheets. Find out what their Rds(on) will be when Vgs is 4.5v to 5v, and multiply that by 5 to find out how much power the MOSFET will be dissipating. Hopefully, you can find something that will dissipate less than 1/4 Watt of power. If not, you'll need to use a heat sink, and possibly a fan to keep the MOSFET from burning up.
