Graph shows.... Just needed to be patient for the 200ms mark.... How do I speed this up/adjust the scale to the 9V, it appears as max 60mv. Maybe the input dc v is not set...
It takes about 48 seconds to finish running on my computer; but I have a Pentium core 2 running at 2.13GHz. If you don't have a dual core processor, it'll take longer. If you are running on a system that doesn't have a co-processor, it will take a very long time.
You could speed it up by reducing the number of cycles on V2, and reducing the frequency. Try 200Hz and 600 for Ncycles, or just 200 and 200.
It'll run quite slowly on a flash drive. You can just copy the LTC folder into a temporary folder on the desktop, and run it from there by double-clicking scad3.exe in the LTspice4 directory.
