HELP!!!! ASKING for PBGA package design
Belle1991
Joined Sep 23, 2025
Dear all!! Thank you for your concern.
I have a product design like this, and I wonder what is the name and function of the rigid Au plating design on this product.
Belle1991
Joined Sep 23, 2025
This is TEPBGA ( thermally enhanced plastic ball grid array). this product belongs to package type ( it is type of PCB with smaller size). The size of whold product is: 32mm * 32 mm for the whole product and the size for the part that I asked for ( die attached areas) is about: 10mm*10 mm. Thank you for your help.
WBahn
Joined Mar 31, 2012
33,277
Thank you for your support. View attachment 356258
Where did that image come from? It's impossible, for me, to tell what is real and what has been overlaid on top of it.
What is the package part number or or at least a fuller description of it.
My guess is that at least some of what is there is related to the thermal enhancement to conduct heat away from the IC and up to the thermal mating surface of the package. Some of it might also be power/ground plane hardening.
ICPackage
Joined Nov 29, 2025
Is that a real picture? The point you marked in the picture seems like to be used as Power or GND. I cant give you more information without a fuller description of it, or a more clear pictuer.
panic mode
Joined Oct 10, 2011
5,307
yeah, those are internal heat spreaders. but i am not designing ICs so i never care about the internal structure. the only thing that matters to me is how IC interfaces to the PCB.
https://www.nxp.com/docs/en/application-note/AN5126.pdf
28,454
The "gold color" on a PCB that gets a BGA reflow solder attached was called "Gold Flash" when I was involved with PCB creation. I never got closer than reading that on the PCB company literature because I never did BGAs nor reflow soldering on any of our creations.
panic mode
Joined Oct 10, 2011
5,307
i don't think question has anything to do with creating PCBs, it is about internal structure of the IC. from what i read they are used to distribute heat and serve as bus bars for power terminals (one such bar can be connected to several IC pins as well as spots on the die)
